I recently installed the B&M shifter on my 04 996 C2 Cab. I also had installed the B&M on my 01 Boxster S that I no longer own. In both cars I have had a minor problem in that the shift knob will pull off rather easily now after doing the B&M install. It has come off on me during shifting while I drive on both my Boxster and my current 996. My question is how can I secure it so that it is attached to the shift lever as tigthly as it was when installed at the factory? I have used quite a bit of pressure to push it back on but it still seems to pop off easily if I pull on it. Does anyone have this same problem and does anyone know of a solution?
Mike
Had a similar problem when I did mine. I just took a soft mallet and tapped the top of the shifter knob a couple of times, and that cured it for me.
Mike, there should be a tightening screw under the shift skirt on the front side. I think it is about a 6MM torx key. It's hard to see if you don't know what to look for. Does yours have one?
Only optional shift knobs (leather/aluminum, carbon, etc.) have the set screw. The set screw is a hex bolt - you would need an allen wrench 5 or 6 mm.
Thanks for the clarification Loren. Didn't realize the standard shifters didn't have a tightening screw.
I have the standard shift knob and there is no set screw to secure it.
Thanks for the idea though.
Mike
Sorry about that. It was worth a try. Not sure what the remedy would be with the standard shifter. Hopefully somebody else can chime in with theior experiences.
Most likely the shift knob is not seated. It takes force to pull it off and force to seat it. I cover the top with a cloth and hit it with a dead blow plastic hammer until I can tell it is seated. Why the hammer, because we use it to hit the wood chisel when we remove the oem plastic bushing for a B&M install so it is handy. Otherwise I pound on the top of the knob with my hand until it is seated.
