Hi everyone:
The Park light on the instrument cluster lights up when I turn on the ignition and it goes out after the engine starts. The problem is that it doesn't light up after I pull up on the parking brake.
The convertible top works normally. I've replaced the parking brake sensor, the micro switch next to the convertible top latch and the dual convertible top control relay. I've used a multi-meter to test voltages in the relay sockets and all seem normal.
So I'm looking for new ideas. As I said the Park light comes on with the key; it doesn't with the parking brake
