 The car starts intermittently with no problem. But sometimes I have the pump the gas pedal quickly about 10 times to get it to start. I clean the MAF and it seemed to run good for a while but then the issue came back. It always starts and runs great at driving speeds.
 Codes are:
P1124
P1397 wheel speed sensor "B"/G – Sensor circuit low input
 P0410 secondary air system performance
 P1411
P0446 the evaporative emission system that control circuit
 P1126
P0102 MAF sensor circuit low frequency
 in that order,  this was done at AutoZone today. Y
These are not easy to deal with codes. I suggest at least get a scanner first if you want to troubleshoot these yourself. Also expect quite involved processes sine these involve the SAI system, the evap system, and the MAF.
P1124 is bank 1 running lean
P1126 is bank 2 runnng lean
P1397 is bank 2 cam sensor
P0140/1411 SAI not operating properly
P0446 evap sutoff valve
P0102 MAF
Loos like you have some vacuum leak, which can also affect the SAI operation. Can you hear the SAI pump runnng the first minute of cold start?
I agree with Ahsai.  You need to start with checking for a vacuum leak, particularly on the intake side of things.  Too much air getting sucked in will throw off the MAF and cause lean running.  Also, having cleaned the MAF many times, I finally replaced it with a new Bosch MAF and that took care of that.  Very carefully inspect your oil filler pipe as they are prone to cracking and that will cause a vacuum leak.  Might just replace that as well.  By process of elimination given that many various codes you will have to go step by step.  Also, buy your own OBDII reader.  They are cheap and valuable.  Better yet, get Durametric for troubleshooting.
