I purchased the Boxster a year ago and the passenger window always squeaked when either raised or lowered. Over the winter, it cased to lower beyond the three inches, or whatever. I hear the motor, and with assistance it still can work. Simply a matter of lube?
Thank you.
:welcome:
Your problem is more likely a worn out window regulator. The regulator is a cable that operates the window up and down.
Do a search here as replacement has been covered many times.
