I took out my 1999 996 recently on the freeway and about 20 miles into the trip all 4 brakes engaged forcing me to limp off the freeway. No warning lights were visible on the dash (abs/psm etc).  Took it to a well respected indie mechanic and he resurfaced the rotors and did a complete brake job with new fluid however the following day the brakes locked again after a short 15 mile trip.
Anyone have an idea on what could be causing this behavior?
Note that I had the brake booster replaced about 18 months ago because the brake pedal was not returning to it's original position. Indie didn't find anything suspect with the new brake booster.
I have the following aftermarket parts installed:
Dectane led rear brake lights
Wheel spacers
Fister exhaust
Any help would be greatly appreciated as it's been at the mechanics for over a month now and he is still trying to diagnose the problem.
user_online.gif http://www.renntech.org/forums/uploads/downloadedimages/report.gif' title="Report Post" alt="report.gif">
Welcome to RennTech :welcome:
When you mention that you previously had a problem with the brake pedal not returning, was that corrected with new booster, or was the car still doing it after the new unit was installed?
I'm in the San Gabriel Valley and have it at a local mechanic in the area.  The new booster corrected the problem with the brake pedal not returning.
Without actually seeing the car, I would start by having the control network for the ABS/PSM checked out.  There are a lot of valves and controls in that system, which are susceptible to build up from corrosion and can jam or malfunction.  I would also try pulling the vacuum line to the brake booster when the brakes are locked and see if that releases them.
Just wanted to say thank you to everyone that responded and provide an update.
Looks like the brake booster was installed incorrectly by a previous mechanic and the pin was not correctly aligned. I didn't notice this for quite some time because the car is not a daily driver and has not been taken on any extended trips until recently. The 30+ mile extended trip was sufficient to cause the brakes to engage.
The mechanic replaced a few o-rings,adjusted the brake booster, and took several 30+ mile trips to see if he could reproduce the issue. Just got home and looks like we are good for now.
Again, thank you to everyone that responded.
