Is it normal when running a fuel pressure test for the gauge to bounce around.  It holds 70 when the car is not running but when I start it, it looks like someone taped a vibrator to the back of the gauge.   It osculates back and forth.  it does appear the mid-point is 70 but is moves so fast it is tough to tell.
I have  a 2008 V6 Cayenne.. last two winters I have a cold start problem where it totally sounds like engine is starving for fuel.  If I keep the car in the garage it is totally fine.  I was thinking it was the fuel pumps and this is what lead me to test.
It did hold pressure well.. it was around 60psi after 30-40 minutes.
Edited by Richard Zellmer
