Hi, does anybody know what size throttle body my Boxster 986 550 Anniversary would have? would it be the 68mm or a 74mm ?
I know they changed a lot of things on this model such as it has the same airbox as a 987.
Many thanks,
                     Adam. (U.K)
  • 3 months later...
The throttle body is the standard small one at 68 mm. I suspect but do not know for sure that the maf sensor housing is larger as it would be required to be to fit into the 987 airbox. The tune and maf /airbox upsizing explains the half dozen extra hp from the earlier car.
