996 & 986 Outer Tie Rod Replacement
Whenever you raise your front end, it is a good idea to "test" as follows:   Hold your tire at 3 and 9 and rock the tire back and forth.....feel play, or knocks?.....Tie Rods may be bad   Hold your tire at 12 and 6 and rock the tire back and forth.....feel play, or knocks?....Bearing may be going bad   In my case, I had a bad "shimmy" around 60 MPH and around 90 MPH....I had already ruled out the balancing of the tires.....   Upon close inspection, I could
