New member/new owner of a 2011 base. I need to change the high mount tail light. Any DIY articles or tech tips to help me out? Thanks in advance!
I'm not Loren, but after seeing your posting - I looked and felt around. There are two recesses which are likely for screws right under the center brake light..
Question - since the light is LED's - and they should last about forever - is there a reason you're removing it?
