I just bought a 2015 981 Boxster with the base radio.  I want to upgrade the sound.  I went to two places.  The first does high end work and said that changing the head unit is a mistake because there is too much connected to it.  He suggested a high end Focal Performance three speaker set with an amp for $3,400.  The second place agreed on not replacing the head unit and said just upgrade to Focal Performance 165AS3 http://www.focal-america.com/product/165as3/ and even without an amp, the sound will be much better.  ($750)
Two questions:
1 - As I understand it, the car has only four speakers now - can I even install a three speaker set?
2 - Any better ideas?
  • 4 years later...
theroost2001@hotmail.com
Here in 2020 I just bought a base boxster with the same radio and speakers.  Did you ever get an answer?  Did you go ahead and make any changes to your radio or speakers?  Did you add a rear camera at the same time?
Bryan
