I am having an issue with the Instrument cluster lights not turning on when I turn on the headlights. Sometimes the lights come on immediately, other times they do not light at all. Occasionally, the will also go out. Any ideas?
Wiggle the headlight switch and see if it has any effect.
If it does, then you need a new headlight switch.
Thanks Loren. The dash lights do drop out intermittently when I move the switch. I will get one ordered.
