In conjunction with the 3.4L engine I am swapping in a 996 gauge cluster. I finally picked up one that will work, turns out to be from a C4 so the gas gauge won't be accurate I guess.
Everything functions fine as far as the gauges are concerned but there seems to be some pin incompatibility between the C4 cluster and the Boxster harness.
With the new cluster the low brake fluid level and the ABS light are illuminated when the car is running. In addition the LCD backlight never goes out even after sitting overnight (long after the actual LCD display goes out).
So I was hoping someone has the pin out diagram from the factory manuals for a early C4. I have the manuals for the Boxster so I would like to compare them and see what I can come up with
Todd
Hmm... it maybe more than a wiring problem. The C4 has a different sending unit to go with the "saddle bag" tank the fits over the front axle. So I suspect the calibration is much different.
Also, is your engine egas or not? All C4's were egas (regardless of year) so I suspect that the cluster for a C4 is expecting some different DME signals.
I'll send you a PM.
Loren,
Thanks for the PM. After comparing the pinouts it doesn't appear that it is a pinout compatiblity problem. It would appear that the cluster in not compatible eventhough the pinouts are the same as are the plugs. Perhaps it is what you suggest, the difference with egas etc. Perhaps it has something to do with the traction control integrated into the ABS on the C4.All the gauges function correctly, with the exception of the fuel level gauge being incorrect just the ABS and low brake fluid idiot lights are lit. Oh well, now I have 2 996 clusters that I can't use (the first one I picked up was a later year with the different connector plugs).
Todd
  • 8 months later...
Loren,
Todd
Hi, did you solve the cluster problem in the end? I have a 996 C2 cluster 1998 with Tiptronic which I want to install on my 1998 non tiptronic 2.5 Boxter.
Any suggestions?
Kare, Spain
That cluster should work since it is from a C2 prior to 2002. I do not think the fact it is from a tip matters, as there was a Boxster owner who put a 996 tip cluster in his manual transmission car.
