had the battery replaced less than 1 year. the 09 CTTS does not start sometimes at first crank, or longer crank. had the battery checked with a shop diagnostics tool. it shows "excess ripple" in the charging current.
does it mean the diodes in the alternator is gone?
is there any way to be sure before I pull the trigger? it is a big job.
thanks and happy new year.
Use an oscilloscope or set the multimeter to AC mV. I don't have the spec for your alternator but usually the AC ripple should be less than 100mV.
thanks but access to the alternator is hard. I suppose the "jump start" contacts under the hood would give some general idea as well?
Yes.
