Hi guys, my driver seat stopped working today.all the adjustments are nit working but when everyytime i removed the key it moved into an upright position. Right now its standing straight up. Used durametric this morning and error in communication and simething about bad ground. Please help.tia
I reconnected some chafed wires at the adjustment plug but still a no go. No more faults in durametric but if i try to erase fault codes a bunch of faults will diaplay all pointing to no signal.Power and groung are ok. Can somebody provide me a wiring diagram or a pinout for the plug for the seat adjustment so i can check where signal is broken. Thank you
