I have Cayenne 2005, on the move while turning my car to ay side on speed above 40 kmph, PSM light blinking in speedometer and the accelerator stops working. when i come back to straight road accelerator starts working again. "if i turn off PSM manually, accelerator is working fine at all times". Can you guide me what might be the problem here and how can i fix it?
For me sounds like a sensor somewhere is causing this. The car has so many sensors for safety and stability. When you make turns maybe one of the sensors is sending out a PSM signal which is almost shutting down power
