Looking to discover what happened with my 2001 top I opened the gearbox that makes the top up and down to check if the gears are ok ....and they are... (found out latter that the cable was he problem)
The problem is how to set the gears position again, to allow the electric switch that is coupled with it to be turned on and off in the right moment.
If someone had the same bad idea to open unnecessarily and was able to assemble again, please help.
Thanks in advance
