2003 996 C2 Tip
It all started with a green patch on the garage floor and my first reaction was a damaged air con pipe from road debris. When I looked further I found the plastic sheath has broken away to reveal a corroded and leaking air con pipe. On more searching I could feel ripples on both alloy pipes under the plastic sheath where the sheath is intact. Pretty poor really as I would have expected longer life.  The corrosion is too extensive on both long pipes to consider a repair joint so I am replacing them both.  Cost of parts is £192. My local garage has managed to recover about 0.5 litres of fluid.
Anyone else experienced this type of damage?
