So I have a 2003 cayenne turbo S 4.5 was in my way to work was going over a bridge lost power and it just died on me. Would not restart got it tied home. So far I checked for spark on all four cylinder on the driver side (just cuz it was easier) tried removing #14 fuse and jusmped both fuel pumps with a wire. Fuel pumps seem to work just fine. What should I look into next?
You need to scan it for codes and any other data that might be available from the on board computer. For most, this might not be possible and you may have done all you can do? You might also want to re-post your question under the older Cayenne heading (9PA). Just a thought. Hope all works out for you.
