I sounds like you still had air in the system.
Would you say that it just needs another bleed?
To be safe, yes. And this time, I would open the inner bleeder first, then the outer bleeder last on each caliper.
Got it. Should i hit the calipers or anything to help get air out?
No, the fluid movement is all that is necessary.
Bled system again and all seems well, there was air in the system which I saw when bleeding, started her up and the pedal was firm straight away.
What a tough job. Was a lot harder than I anticipated but at least it's over and my calipers are new and yellow!
They also don't squeal anymore, I put this down to new shims and brake lubricant on the contact points.
Thanks for all the help!
Edited by no1joey
