Hi, im from the philippines and new to the porsche scene.i just traded my e53 to a 955 turbo and i am doing maintenance right now. I have a brake booster error and i saw that there is a broken Vacuum T at the back of the intake and the hose runs thru the pass side valve cover. I am having a hard time dissasembling it as it is somehow attached in between crimped hoses which is attached to a solid tube that runs thru the side of the engine. Can someone tell me what line is this? I just epoxied it back as it's a PITA to remove and replace. Would want to replace it as its broken off Thank you
