I am in the process replacing my primary cats. To remove the passenger side, I need to remove the front cardan shaft. It seems to be seized to the front axle connection. Does anyone have a tip on how to get it to break loose?
Note: When I replaced my rear cardan, I used a bearing splitter to separate it from the rear axle. I don't think there is enough play in the cardan for doing this also on front.
Darren
