I have a 91 tuned file with approx. 620 hp; my question is if I was to increase the octane to 93 would that add any performance or benefits with a 91 file; I can mix 6 gallons of 100 octane with 20 91 to get close to 93 octane.
Thank you
post-59175-0-49833400-1447019033_thumb.j
Edited by Dominic123
Thank you
The DME might be able to run a bit more timing with out detonation, but any speculation about how much additional power it would make would have to be determined by dyno pulls.  I would suspect, however, the gains would be slight enough to not be worth the effort.  You might pose the same question to whoever wrote the reflash software.
