I get ABS failure and PSM failure at start up.
A scan at Porsche resulted in the above code and a list of things to check.
Am going to try and find the bits on the car tomorrow and test.
I am also going to be looking at the ECU as this might also be caused by it getting wet.
Have attached the full list of info I got from the report.
Any help appreciated :)
Cayenne Full Report 2.pdf
Fault code 1673 -- Distance sensor in brake booster
Possible cause of fault
- Actual value of 'distance sensor in brake booster' is evaluated as implausible (implausible signal)
- Short circuit to ground (electrical fault in electric circuit)
- Short circuit to B+ (electrical fault in electric circuit)
- Open circuit in circuit to control module (electrical fault in electric circuit)
