Both rear windows on my CAB will not go up using the switches, top up, and key for top up, checked the fuses, Checked the switch and 12v power switched for power and it was present. any Idea how to bypass the system to bring them up?
In order for the rear window to up with the top down you have to stick your finger in the top latch opening and press the micro switch, all works fine can now but all the carpet and panels back.
