I purchased a red 912E recently and the previous owner had put on 195/60 on R14, the car looks a bit silly with those little tires. However I am debating wether to go to the original 185/70 R14 but I want to make sure the look is good, or else I might bite the bullet and go for 16's. If I end up doing that I will ask for suggestions on tire size...but that will be another post later on. If you have a 912E can you share side views and specs in the wheels & tires as well as impact on the speedometer? post-2764-0-36313100-1446360642_thumb.jp
Edited by scherb
