I had a klunking noise coming from right front when driving on bumpy roads. I thought it should be the lower control arm. I had i replaced some time ago. Nothing changed. Still the same. In which way i could find out what part is causing this? Any possibility to get the parts tested on the front suspension?
Thank you for your input.
Thomas
I would love help with this also.  I have replaced the lower arms, upper arms, sway bar links, sway bar bushings, and tie rods.  I still have a bad clunk on bumpy roads.  The only items left are steering rack, top of the air shocks(bushings?), or axles.
Any help would be appreciated.
Ryan
Hello Ryan.
I was surching arround in different places and i am concerned it could be the axle. Maybe a professional here at renntech can confirm it or giving advice how to test a bad axle. Thankx
