If I open the hood and facing engine, where would cylinder 1 location be located.
Have received fault PO301 which is cylinder 1 miss fire; had all plugs replaced by porsche shop after issue 2 weeks ago and fault coming back more frequent; check engine, psm, and start/stop messages will appear and cars runs very rough; shut off and restart and lights will still be on yet runs fine; then after driving for a day all light go away and no issues.
Have run 4 tanks with techron and issue still happening.
Thinking to switch ignition coil from 1 to 3 and when fault happens again see if code different to determine if it's bad coil or maybe injector.
Any insight or suggestions would be appreciated
post-59175-0-56247700-1445658974_thumb.j
Edited by Dominic123
  • 2 years later...
