Basically, the 996 C2 brakes are the "same" as the 986S, however, upon closer inspection, almost all of the key part numbers are different except for the front rotors and maybe sensors/clips. I'm trying to figure out exactly what is interchangeable or not between the 986 S and 996 variants.
Does anyone know if the 996 330mm rear brakes (off a C4S/TT/GT3) will fit a Boxster S? In particular, I've heard that the rears will bolt right up. Has anyone actually done this and are the rotor offsets/brake line connections/etc. compatible?
I know the front brakes of the C4S/TT/GT3 use a different wheel carrier with different bolt spacing, but I've heard the 986S can be retrofitted with the different wheel carrier as well.
Anyone have some "concrete" information on what parts fit?
