Hi everybody:
Searching the forums in regards to the instrument cluster found this info in an old post:
"The second one (996.641.103.01.70c) was replaced by 996.641.103.02.70c and then 996.641.103.03.70c -- so it will work but it is likely from 1998."
Having problems with the tachometer, the needle dropped and although it tries to move is always pointing to the #6 position on a clock dial. The other problem is the the cluster clock can not be adjusted. None of the functions of the knob to set the time on the cluster clock work (setting time and changing from MPH to KPH).
Thinking of getting a cluster, my car is a MY99, C2, manual, and activated OBC so, would any of the clusters above mentioned would work, what reprogramming would be needed for the "new" cluster? I know the millage would need to be adjusted and either VDO Repair or Palo Alto Speedometer could.
