I Have a '97 boxster manual and i am getting only 1 code (P1125) -Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold. It is confusing me because everywhere ive looked people always have more than 1 code with this. I diconnected the MAF to see if it was the problem but it drove way worse than normal. Any thoughts?
Welcome to RennTech :welcome:
P1125  is the code thrown when the air fuel mixture on bank 4-6 becomes so rich that the DME cannot compensate.  Most common faults are a leaking injector or the fuel pressure has gone very high.
