First --  make sure your Cayenne Turbo does NOT have 19 inch brakes - because if you do have 19 inch brakes then these wheels will not fit.
Those are correct part numbers, widths, and offset - so make sure the part numbers are on the wheels also. I would ask for photos of each wheel - plus that provides you with prior knowledge of scratches, dents, or cracks.
Im picking them up in person, so I will be able to check each wheel. I actually have a Q7, so no problem with brake clearance. Thanks for the tips.
