My 2008 cayenne´s left side front and rear door lights quit working? There are 2 lights  at each door. Bright and red , none of those lights anymore?  Right side works fine and all other interrior lights etc.. ? all fuses are OK, so ???
I'd see if you can swap one of the light assemblies from the opposite side in to see if it works.  If not, then I'd guess you have a wiring issue somewhere.  No clue where you would begin looking for that.
I tried that too..it´s not the light assemblies.... ?
