Cut the wall of my left front tire on the out track of turn 7 of Blackhark Farms Raceway today (apparently they put speed bumps just past rumble strip to discourage cars from braking too little). Kind person gave me a spare to get home. I'm currently using MIchelin super sports 235/35/19 for all four tires. They don't have a lot of wear on them as it's pretty much a track car only for me these days--I've put maybe 4 tracks days on them (including 2 days at Road America), probably 1-2K miles max.
Do I need to replace both front tires? Or is it ok to replace just the left front?
You certainly can replace all 4 and be assured you have matched handling characteristics..
But if you plan on much track time you might want to consider "street tires" and "track tires".
Street tires don't really have "heat cycles" like R compound tires do. I'd be inclined to replace the one damaged tire. If needed, Tire Rack could shave the tire a 32 or two, to match the other current tire.
Sounds like you were running our last DE event of the year at Blackhawk. Someone gave you a spare tire! That's awesome. Lots of great guys/gals in our Chicago Region PCA.
