Hi, ive got a small issue I'm hoping someone can help with. The passenger door window doesn't come down a little when I pull the internal handle. Also when I pull it from the external handle it comes down but goes up straight away when I let go rather than when the door closes. Are both microswitches duff? Window goes up and down fine so the regulator is OK.
Thanks in advance
Immy
It sounds like you have a door lock microswitch problem in the door as the cars still thinks the door is shut/locked and window stays down or goes back up.
The inside and outside handle microswitches are available separately.
Part Numbers:
Inside handle microswitch: 996.613.123.xx (Same both sides)  (<$50US)
Outside handle microswitch: 996.613.125.xx (Left) / 996.613.126.xx(Right)
(xx is latest version)
The door lock microswitches are not available separately, and you have to buy the complete door lock assembly, at a cost of around $220US or so.
I would recommend becoming a contributing member to access the DIY section.   Everything you need to know about door microsensors/switches can be found here in a article posted by member Richard Hamilton.
http://www.renntech.org/forums/tutorials/article/217-door-microswitches/
Edited by kbrandsma
