I'm not seeing any DIY on replacing the front CV joints and or stub axles.  I assume this is because it is really easy...  I'll take pictures just in case.
Tools needed:
32mm 12 pt socket.  (not 36mm as some online guides suggest)
post-53634-0-98427000-1443203721_thumb.j
Edited by ARModen
I used a short breaker bar with a floor jack under the end to get the nut loose.  I believe it's 380ft-lbs but not positive.  A 2-3 foot long wrench means ~200lbs of force so either reverse the floor jack plan, or stand on it.  I probably won't even bother if I don't have a torque wrench with that range handy, just make it REAL tight with my breaker bar.  I bought to the socket at Northern Tool.  You may want to get a deep well so you don't need an extension to reach it.
  • 4 months later...
