Trying to buy an 02 996 Cab.  Did the PPI today and ran across a strange issue.  I've discussed it with the PPI mechanic and my mechanic and neither are certain about this issue.  When the car is parked in the sun with the doors locked the alarm horn begins to sound after about an hour or so (when it warms up).  PPI mechanic says he has seen it on two other cars, all 996 Cabs.  Local mechanic says he has seen something similar with the "horn frame."  PPI mechanic says this is NOT "horn frame," it definitely has something to do with the immobilizer, and the car is NOT throwing any OBD codes.  Car checks out great other than this issue.  Just a few wear/tear items like brakes, rotors, and coil pack that I'm okay with.
Any ideas?
OBD II codes are emissions codes and have nothing to do with alarm fault codes.
You need Durametric or a Porsche diagnostic tool (like a PST2 or PIWiS) to read alarm fault codes.
It could be a bad sun sensor but the alarm code readout would say for sure.
Loren,
My mistake.  You are correct.  My understanding is this was run on a PST2 and there were no alarm codes.
I'm not sure but I'll know soon.  I decided to purchase the car.  It's on it's way from TN.  I'll resurrect this thread when I have the car in my possession and I can give more complete info.  Thank you, Loren!!
  On 11/22/2015 at 1:44 PM, ghiaguy0 said:
Any update on your issue. Mine does the same thing. Mine does beep 2 times.
If your alarm beeps twice when you lock the car you have an alarm fault.
You will need a diagnostic tool like Durametric or Porsche PIWIS to locate the fault for repair.
Many times the 2 beep alarm fault is because the center console arm rest storage door is not fully latched, or the rear side windows are not closed.  Because the interior security motion sensors are IR based, sometimes when the car's interior gets hot, the movement of the stratified air in the cabin will set off the alarm.
Also make sure the hood and boot are fully closed and latched.
