I need to get some advice please -- I've got the following codes by Duramtetric coming up on the PC:
1800 - Position of Crankshaft (Intake) - Upper limit exceeded
9722 - O2 Sensor Bank 1 dynamic Response too lean
7101 - Lambda Control Adaptation bank 1 system too lean upper limit exceeded
9521 - Signal too rich (o2 sensor ahead of cat) bank 1
9721 - Signal too rich (o2 sensor ahead of cat) bank 2
The throttle is a bit out of whack sometimes power is down and CEL is on..
I thought it was a Cam Angle Sensor issue -- but there are two of them? Is it likely the Inake side?
Assuming this will fix the O2 sensor issues as well ..
Thanks in advance.
