Porsche Carrera 4S. The battery is dead and in order to change the battery I need to pop the hood. Only problem is that the hood is opened electronically. Any ideas ?
Couple of them; if you have a battery maintainer, plug it in to the cig lighter and wait an hour or so until the battery builds up some juice, the trunk will then open.  On the driver's kick panel there is a fuse panel with an indicated power lug; attach another battery there and the trunk will open (for more on this, check your owner's manual).
