Hi 996 friends,
Excuse the question, but I am confused as to specs saying fluid capacity is 10 liters or so but only 4 during fluid change. What does this mean? does it mean when it gets drained 10 liters come out or only 4?
Thanks for the clarification!
I have a 996, 1999 cabriolet, 2wd.
Randy
By far, most of the Tip's fluid is in the torque converter, which you cannot drain by draining the pan.  At most, you will get out 4-5 L from the pan.  This is one of several reasons we recommend changing the fluid in the Tip more frequently.
I also removed your double posting on this topic; please do not double post, it is against forum rules.
