I went to the Kindel site to use the decoder and was not able to find what option 226, 246 and 665 were for. Anyone have an idea? I also found a code 09991 which Kindel says is for the Exclusive Program. Does that mean the car was special ordered? Thanks for your help!!
226 does not come up on the list - how about 236 - 18" tires?
246 also does not come up - perhaps 249? Tiptronic Transmission?
665 - PCM2 basic module (no phone) with radio
09991 - Exclusive Program likely means that one or more items on the car came from the Exclusive list (one or more codes starting with "X").
Loren, those are probably correct, the car has 18" tires and it is a tiptronic with PCMII. That completes the mystery, as usual, we are all beholding to you for your knowledge. Thank you.
