I had the end come off my shifter cable, it simply looks like the pressed fitting let go at the transmission.
I know buying used cables is a roll of the dice, but are the 5S and 5S cables the same ?
I have a 01 S
Also it looks like I could just reill a hole in the octagonal part through the cable end and simply put a pin in it ??
Anyone ever try this ??
Thanks in advance
Dwight
