Hi my 05 cayenne is stuck in Park
The Shifter will not move you can release it by the manuel emergency method and gears are fine car drives great.
Also you get a click from the solenoid when you press the brake pedal
It is the other solenoid
I have replaced the switch on the gearbox
There is no power going to the solenoid
All the fuses at either end of the dash left and right fuse box are fine
Any ideas please
