Good Day To All
Noticed increase nosie on Engine Start. Sounded like busted exhaust.
on investigation found blowing between Exhaust Manifold LHS and Catalytic converter. The nuts on all 3 screws are completely rusted and after cooling down the 2 parts can be separated slightly.
The 3 screws and locking nuts are shown on the parts diagram as not connected to the Cat.
My problem is that i can get the screws out to replace them with the exhaust still on the car.
Any advise
thanks
Hi, I did this about 2 years ago.  Just get a high speed 1/4" diameter x 20k rpm electric or pneumatic grinding tool and a bit with a fine pattern for carbon steel removal.  The tool I used is cylindrical with a spherical top.  Use eye protection (glasses + a face shield).  I removed the rear fascia and the heat insulation piece and you should have adequate space to grind the fasteners.
