Has anyone replaced the oil sending unit on their 997.1 MT coupe? Is so would you say it is an easy, moderate, or high difficulty task?
...j
Do a search in the 996 section as 997-1 uses the same problematic oil sender.
A 5 minute job with the right tool - or a more difficult job without the right tool.
I can confirm this is an easy driveway job. 20 minutes.
I have a 2005 C2S MT. Symptoms - oil pressure above zero when engine not running, many times the pressure pegged at 5 bar (cold, hot, high rpm, low rpm).
Firstly, just tried reseatting the two (spade) connectors (can't mix them - they're two different widths) - it's just stick your arm in there on a non-hot engine. No joy on the gage though.
Bought $70 part off Amazon (996 606 203 02); comes with aluminum sealer/washer. [it definitely looked like a Porsche part when I inspected it.]
Tools: 3/8 drive 19 mm crowfoot wrench, 6 inch 3/8 extension, 3/8-1/2 drive adapter, 1/2 inch ratchet, trouble light
If a lot of debris around the area, clean it out now.
Remove electrical connections to sender.
From the "top" (engine bay), reach and fit the extended crowfoot to the sender at a good position to break it loose.
Fit the ratchet to the extension; break the sender loose.
Use hand to completely unscrew it.
Hand thread in the new one until the sender/washer seats.
Re-fit the crowfoot.
Use good judgment about how much to torque. Not really too much owing to the aluminum washer/design.
Re-fit electrical connections.
Fired electrics with key - pressure gage at zero.
Started vehicle - pressure to 5 bar (typical for cold behavior).
Turned off; fired electrics - pressure at zero.
Stuck my arm into the engine bay to see if I could feel any wetness/oil - none.
