Guys, this site is a bit of a double edged sword for me.  One on side, I love to post and get feedback from the most knowledgeable group on the internet.  On the other, it usually means that I have a problem.
I have an 01 Turbo that has a Rennline Kill Switch.  If I don't use this switch, my battery goes dead in a couple of days.  Well, I should say sometimes it does, sometimes it does not.  There are days when I stop for an errand and come out after 15 minutes and my car turns over, pauses for a 3-4 seconds, then turns over.
I tested both the Volts and Amps tonight with my Bosch Multi.  12.63V across the battery.  .08 amps (with the negative terminal disconnected) between the negative lead and negative post.  If I turn on the Rennline- amps drop to 0.
Beyond perplexing.
Anyone ever experience this?  Thoughts?
There are times when I get weird electrical errors- like PSM or ABS lights come on, etc., but then stay off once I use the Rennline.
Is the kill switch okay to use daily- any problems with doing so.
I will check my volts on the battery in the AM to see where I am relative to the 12.63 tonight.
Did you try a search (before you posted this 3 times)?
I think not.
40-60 ma is normal - anything else means you have a drain.
Put an amp meter in series with the battery and slowly pull fuses until you find the circuit with the large drain.
Report back here which fuse.
Loren, thanks for the reply.  Quite honestly, it did not appear to me that my initial post (or 2) was successful.  I apologize for the repeated posting.  I do appreciate your role on this board and I will do what you suggest and report back to the group.
Thanks again.
Loren- I am shooting for a single post/reply.
Waited about 45 minutes for the car to quietly shut down.  Still pulling about .08 amps- obviously high.  Pulled every fuse without much response- in one case it dropped to .7 which was better, but not where we need it to be.  I believe the previous owner has an outlet wired behind the radio for what looked like an external antenna- you could literally plug a car phone charger into it.  Nothing is plugged in right now- but would this be a source.  Would the Rennline draw power?  Again, as soon as I shut off the kill switch, the amps from from .08 to .00.
Still perplexed- anything else you can think of?
I will continue to search forum tonight for answers...
Well... if you have third party things on the car they may or may not be wired through the cars fused power system.
In that case you need to do the same - disconnect them one at a time and see what the amp meter says.
In my experience 9 times out 10 it is a third party installation. Having seen a friends 911 burn because of radio install was the worst I have seen.
So what ever the cause you need find it and fix it or remove the third party device (IMHO of course).
