I'm a little apprehensive about upgrading to the new MS Windows 10....
Mostly because I'm dependent upon the Durametric software working properly.
I contacted Durametric and they said they are working on testing for compatibility.  So far so good from their perspective.  And they mentioned that some users had successfully run V.6 under Win 10.  But Durametric won't give it their blessing for another month or so.
Any one here try and have any problems running Durametric under the upgraded Win 10?
You could try running the program with compatbility settings for previous versions of windows. I have version 5 running on Windows 10 and it works fine but looked 'fuzzy' the first time I ran it, I did some digging and discovered I needed to tick the option in compatability mode: 'Diasble display scaling on high DPI settings', I'm using a very high res 4K monitor.
Works fine.
Edited by Robinm
