Is distilled water all I need? Just checking...
Also, are any of you guys running gel batteries? I have tracked many times with the OEM battery without problems. What are the advantages of using a gel-based battery?
TIA. :rolleyes:
Distilled water is a very good idea as it does not introduce impurities into the battery.
Most tap water/rain water etc has impurities which can affect the plates on a battery in the long run.
Gel cells have the main advantage of not requiring any top-up fluid etc and therfore being sealed - no acid spills etc.
Typical gel cells have a disadvantage in that the internal construction is not necessarily as robust as a normal car battery. You can have plates fail internally due to vibration etc. There are some exceptions where industrial/heavy duty usage gel cells are utilised.
Another problem with gel cells is that their float voltage is slighty lower in comparison to a normal lead-acid wet cell, therefore if you have long term usage of the gel cell in your car, the cars electrical charging system will tend to over-charge the battery over a period of time thereby reducing its life.
Costas
Edited by ZX7R
ZX7R...
Interesting info on the gel cells. Much appreciated. I haven't had any issues with my OEM battery. I think I'm going to stick with the dH2O. :)
