Hi have a 2005 Cayenne with PCM
I have lost all audio sound just get error message, have tried fuses etc.
Got into it a bit deeper linked out phone module under drivers seat and cd change below amp.
Still no sound, then linked every bit of fibre optic cable i have and connected PCM directly to Amp
still got error message but got SOUND
So am now thinking i have a damaged fibre optic cable
Does anyone know the correct sequence the light has to travel
thanks
Sorted
Looked like it was a fibre optic because I looped out everything except PCM and amp and had sound
Found a bad join in wiring under drivers seat that provided wake up signal to phone module navigation drive and cd changer.
