I recently completed the Battery/Starter/Generator Cable replacement.  Attached is a newbie-rated, pic-intensive write-up.  Below is the introduction and table of contents so readers can decide if the document will be of use before downloading the pdf.
 "Recently I changed the infamous Battery/Starter/Generator cable on my 997.1.  My car had been a bit sluggish on starting for some time, but, one day when I tried to start it after the engine was at operating temperature it would not start at all, as if the battery were dead.  The next morning, after cooling off overnight and without charging the battery, it started.  I researched the various Porsche forums and found that the aforementioned cable was the likely culprit.  The revised part number for this cable, as of this writing, is 997.607.019.03.  So, I ordered the part and undertook the replacement.  Special thanks to ‘yvesvidal’ from 6speedonline for his tutorial, as well as a thread by ‘equinox’ on 6speedonline that ‘yvesvidal’ used, and a more brief but, nonetheless useful, post by ‘jkw911’ on rennlist.  I followed yvesvidal’s procedure quite closely, though I did change the order of some portions.  I’m a detail-oriented person and what I always hope for is that someone has created a highly detailed, picture-intensive write-up of a given procedure (so I won’t have to).  Knowing that there are others out there like myself, I put together my notes for this procedure for my future reference and am posting it for those who would find it useful.  This write-up is not for everybody as it is newbie-rated, highly detailed and pic intensive.  To gauge time-to-completion, I’d guess that I spent 8 hours working on this job.  Having now done the procedure, it would be faster, especially with this write-up.  A note of caution before embarking on this procedure:  as always, there are an infinite number of ways to screw things up so one undertakes this procedure at their own risk.  What follows is how I completed the job and, as they say on the forums, your experience may vary."
TABLE OF CONTENTS
CHAPTER 1:  INTRODUCTION
CHAPTER 2:  PARTS, SUPPLIES, TOOLS AND PRELIMINARY WORK
  1. Parts and Supplies
  2. Tools
  3. Preliminary Work
CHAPTER 3:  REMOVE REAR UNDERBODY PAN UNDER ENGINE
CHAPTER 4:  REMOVE AIR CLEANER HOUSING
CHAPTER 5: REMOVE DRIVE BELT
CHAPTER 6:  REMOVE THROTTLE BODY
CHAPTER 7:  REMOVE PLENUM
CHAPTER 8:  REMOVE POWER STEERING RESERVOIR
CHAPTER 9:  REMOVE GENERATOR
CHAPTER 10:  DISCONNECT TUBES FROM AIR OIL SEPARATOR
CHAPTER 11:  DISCONNECT CABLE ON STARTER
CHAPTER 12:  DISCONNECT CABLE ATTACHMENTS FROM UNDER THE CAR
CHAPTER 13:  REMOVE THE AIR CONDITIONER COMPRESSOR
CHAPTER 14:  DISCONNECT CLIPS AND REMOVE CABLE
CHAPTER 15:  INSTALL CABLE
CHAPTER 16:  INSTALL AIR CONDITIONER COMPRESSOR
CHAPTER 17:  CONNECT AIR OIL SEPARATOR TUBES
CHAPTER 18:  INSTALL GENERATOR
CHAPTER 19:  INSTALL POWER STEERING RESERVOIR
CHAPTER 20:  INSTALL PLENUM
CHAPTER 21:  INSTALL THROTTLE BODY
CHAPTER 22:  INSTALL DRIVE BELT
CHAPTER 23:  INSTALL AIR CLEANER HOUSING
CHAPTER 24:  INSTALL REAR UNDERBODY PAN UNDER ENGINE
CHAPTER 25: WRAP-UP
997.1 Generator-Starter-Battery Cable Replacement with Pics.pdf
  • 4 years later...
The directions are great.  However I am stuck on chapter 13 and getting to the rear bolt off of the compressor.  Do you recall what combination of extensions you used to get the socket to sit flat.  I have been trying to find the right combination for way too long over the last couple of days.  Any help would be appreciated.
