Curious if anyone knows if these two lines can be replaced / accessed through the right rear fender area? If not, then will I be able to achieve this by removing the AC? I need to replace these two hard lines that connect hoses to the lines that run along the bottom of the car up to the rack & pinion. I unfortunately went plowing in my car and something caught the two lines and mangled them. Any suggestion is appreciated in advance. 5&6 in attachment Larry
post-23578-0-89625800-1438386044_thumb.j
